Date/Time: Sat, 28 Dec 2024 08:17:06 +0000
Add parallel lines to Current Price Line
View Count: 868
[2016-04-28 08:25:43] |
User840240 - Posts: 1 |
Hi, I would like to know if it is possible to add parallel lines to the current price line indicator for example I would like to have one line 10 points up and another 10 points down the current price line so these lines move just as the indicator thus creating a real time evolving price range thank you |
[2016-04-28 08:53:45] |
Yes it is. Use the Study Subgraph Add study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s272 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
