Date/Time: Sat, 28 Dec 2024 08:48:44 +0000
complex attached order
View Count: 619
[2016-04-28 05:05:21]
aydex - Posts: 110
Please let me know if an order as described on the image attachment is possible, via help from support, or an independent consultant's work.
Circled are the chronological steps.
There are two simple brackets, the 2nd is dependent and it's placement is triggered after the 1st's entry.
thanks
Date Time Of Last Edit: 2016-04-28 05:39:26
imagecomplex.PNG / V - Attached On 2016-04-28 05:04:21 UTC - Size: 10.49 KB - 221 views
[2016-04-28 17:32:25]
Have a look at:
https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#TriggeredLimitOrderEntryStudy
Also for the Target and Stop, these are Attached Orders. These are documented here:
https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html
