Date/Time: Fri, 20 Sep 2024 00:39:27 +0000
Price Action Indicator or study.
View Count: 3108
[2013-07-09 04:58:18] |
User86222 - Posts: 10 |
Hi, I was able to get all of my indicators that I use in Ninja Trader to work in Sierra Chart studies except the Ninja Trader Price Action indicator. This indicator will automatically create a LL, HL, HH, LH, DT, and DB on your chart. Can you please tell me how to get this in your platform and/or can you put this as a request for development of your next release. Thanks, |
[2013-07-10 12:03:21] |
Have a look at the Market Structure study and see if that meets your requirements. At least partially. Otherwise, we need very specific details as to how each of these labels is determined. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-10 12:14:47
[2013-07-10 19:13:23] |
Yes, the Zig Zag does the job once you play with the settings for an hour to get it right. It will do. I have no idea why someone would by default turn the labels off which is why I probably never used it before. Thanks. |
