Date/Time: Thu, 24 Sep 2026 01:03:39 +0000
Speed up spreadsheet allocation of data
View Count: 1143
[2016-04-27 17:38:24]
User713273 - Posts: 409
Im wondering if there is a function that would speed the time it takes data to populate in the cells in the spreadsheet. Currently getting frequent delays. Current version 1399.
[2016-04-27 18:26:34]
Yes. Reduce the Number of Rows Spreadsheet Study Input setting:
Spreadsheet Study Inputs: Number of Rows
You want to keep that to the absolute minimum that you need. Preferably less than 100.
[2016-04-27 21:28:12]
Yes have reduced the amount of rows to 10, which is the minimum. Still have delays. Im am directly connected to my internet provider.
Anything else you can provide that I try?
[2016-04-27 22:07:16]
Without knowing exactly what you are doing and how many Sheets are being used, not sure what else we can recommend.
Although you can set a nonzero value for Chart >> Chart Settings >> Advanced Settings >> Chart Update Interval. Use a value of 1500.
