Date/Time: Sat, 28 Dec 2024 08:25:58 +0000
SC pack 3 DOM customization
View Count: 1636
[2016-04-27 16:16:23]
User305145 - Posts: 38
I have a funded acc with AMP and consider using SC pack 3. Some questions as to what degree of customization this version will allow me to do:
Attached pic - is this level of DOM customization made possible under pack 3? (or is this some other version?)
Can I do it myself directly from the "Customize TradeDOM Columns"?
Kind Regards,
Martin Byller
imagecustom sc2.jpg / V - Attached On 2016-04-27 16:11:52 UTC - Size: 78.04 KB - 365 views
[2016-04-27 17:07:34]
This is a Trading Ladder / DOM from Sierra Chart.
So all you see is supported with service package 3.
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html
Date Time Of Last Edit: 2016-04-27 17:15:52
[2016-04-28 04:14:58]
How do I adjust the font size in the DOM?
I have tried Chart -> Graphic Settings -> Fonts
But no changes I make are applied.
/Martin
[2016-04-28 04:22:47]
Unchecking "Use Global Graphics Settings......" did the job.
[2016-04-28 04:37:43]
Hi again,
Slowly getting to grips with the DOM.
But;
How do I adjust the row height in the DOM window? (Basically I wish to see less prices, everything larger/more magnified)
How do I change the font size of the price column?
/Martin
imagecustom sc3.jpg / V - Attached On 2016-04-28 04:37:25 UTC - Size: 101.09 KB - 306 views
[2016-04-28 05:07:43]
You can only do this by increasing the Chart >> Chart Settings>>Tick Size but that has the consequence of preventing order entry at smaller tick sizes.
To change the font size, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_ChartTradingCustomizingGraphics.php
Date Time Of Last Edit: 2016-04-28 05:08:12
[2016-04-28 05:15:11]
You can increase the spacing between the horizontal lines by adjusting the Scale Increment setting:
https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html
