Date/Time: Fri, 18 Sep 2026 00:42:43 +0000
Order Entry
View Count: 1002
[2016-04-27 15:22:15]
User21113 - Posts: 62
Topic: Order Entry
Is it possible to add trade order entry buttons to a Control Bar?
The current options appear to be
• Trade Window
• Hot Keys
• DOM
While each order entry tool has it's benefits, adding Buy and Sell buttons to a control bar would produce a very small footprint on the screen that could be located very near the price.
If that is not possible,
• Is there currently any other way to do something similar within Sierra Chart?
• It is possible for a user to program this feature, similar to the ability to create a new study?
[2016-04-27 17:25:35]
You can use the Trade Window which has a compact (C) tab:
Basic Trading and the Trade Window
You can also use the Chart DOM:
https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM
You can also enter orders through a shortcut menu:
Chart Trading and the Chart DOM: Entering Orders From the Chart
