Date/Time: Sat, 28 Dec 2024 08:36:49 +0000
Synthetic Spread
View Count: 1092
[2016-04-27 14:44:27] |
User688515 - Posts: 5 |
How do you create a synthetic spread? Can this be with various ratios?
[2016-04-27 17:26:48] |
This can be done with the Difference study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s3 Different ratios can be done with the use of the Multiplier Inputs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
