Date/Time: Fri, 20 Sep 2024 01:12:17 +0000
V993 Chart Scale Menu Issue
View Count: 1411
[2013-07-09 03:36:20] |
ged - Posts: 233 |
In V993, when the chart scale is right clicked and the menu appears, in all previous versions a checkmark would appear by either: Interactive Scale Range, Interactive Scale Move, or Interactive Scale Locked. That check mark is missing in V993.
[2013-07-09 17:10:36] |
Sierra Chart - Max - Posts: 5662 |
We do see this problem, and it will be resolved.
Sierra Chart Support |
[2013-07-09 20:18:14] |
We apologize for not being completely clear by what we meant when we said "fixed" in response to your other posting about this. This has been corrected, and will be out in the next release. We have made this new release, it is version 994. Please update now by selecting Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-09 20:57:52] |
ged - Posts: 233 |
Thank you very much. I really appreciate the exceptional quality and hard work of SC Support.
