Date/Time: Thu, 10 Sep 2026 20:48:13 +0000
Russell (ICE) data issues
View Count: 1017
[2016-04-27 14:04:10]
Cavalry3162 - Posts: 523
Hello SC,
unfortunately the data issues with ice (russell 2000 emini++) are back..
please double check what the issue is.
thanks,
Andreas
[2016-04-27 15:07:53]
any ETA? this is really annoying. stops moving for minutes and then a "loading historical data"...
i need a reliable feed for my trading.
thank you.
[2016-04-27 16:14:28]
We are checking on this.
[2016-04-27 16:29:20]
We do see the problem. We apologize for this. It really is not good.
It is not on the side of Barchart. It is a problem on our side. We are doing a software update at this moment that we expect will correct it.
Date Time Of Last Edit: 2016-04-27 16:29:36
[2016-04-27 16:30:39]
thank you.
appreciate the quick fix.
[2016-04-27 16:40:11]
So far the Open Feed connection which was previously intermittently getting lost, looks stable. We know why this was happening. It was a problem in the latest software update.
We will be seeing if there is any missing data and patching that in the evening.
Date Time Of Last Edit: 2016-04-27 16:40:46
[2016-04-27 18:28:23]
We can confirm the data feed is now stable.
Once again we do apologize for the issue. A lot of work went into getting this Open Feed released but there were a couple of stability issues which are now all solved.
We expect the data feed to be stable from this point on.
