Date/Time: Sat, 12 Sep 2026 03:33:27 +0000
Angle on Study
View Count: 1292
[2016-04-26 20:33:30]
User937866 - Posts: 12
Is there a way to color Bollinger bands based on their angle. For example, I would like the bands to be colored based off a 15% or greater angle. Thus, if the upper band is sloping up 15% or more it will be green, if the lower is sloping down 15% or more it will be red, if the slope of either is less than 15% they will be colored black. I have messed with the study settings and can't get them to work out how I would like.
[2016-04-27 03:47:57]
This can be accomplished with the following two studies:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s231
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245
For the Color Bar Based on Alert Condition study, refer to this specific section for coloring the Bollinger Bands:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s252_ColoringSubgraphsOfOtherStudies
