Date/Time: Mon, 23 Dec 2024 15:55:39 +0000
AccumVol does not include 1st bar of day
View Count: 1071
[2013-07-09 02:43:32] |
joeroma - Posts: 43 |
I noticed that, when I use a chart with just a 1-day setting, the Calculate ZigZag Value input does not include the volume of the first bar of the day in the first swing. Thanks. ------------------------- I submitted the above question about a month ago but didn't receive a response. Don't know if you are too busy at this time to address it or it was just an oversight. The attached chart shows the problem in addition to printing values when they are less my specified 2.75 for Reversal Amount for Calculation Mode 2 input. This problem occurs only around the opening. Thanks. http://www.sierrachart.com/image.php?l=1376012879830.png Date Time Of Last Edit: 2013-08-09 01:49:31
[2013-08-09 01:46:13] |
Please see previous post
[2013-08-09 17:59:14] |
We will be looking this over.
[2015-10-08 15:13:39] |
Just re-visiting an old issue which has not been resolved yet. I noticed that the volume of the first bar is included in the accumulated volume of the last swing of previous day when the last bar of the previous day was not the swing high/low. But when the last bar of the previous day is a swing low or high then the volume of the first bar of the current day stands alone and is not included in the accumulated value of the first swing. Can you please address this issue when time permits. TIA
[2015-10-09 18:05:51] |
Regarding this, do you have Reset Zigzag at Start of Trading Day set to Yes? If so, we think we understand what you mean and we will make sure this works consistently as when the option is set to No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-13 04:35:14
[2015-10-09 18:41:23] |
Reset Zigzag at Start of Trading Day is set to Yes
[2015-10-13 01:10:56] |
Al SC Developer - Posts: 434 |
This should be addressed in the next version.
