Date/Time: Sat, 28 Dec 2024 08:40:09 +0000
Length of Candles
View Count: 642
[2016-04-26 18:17:14] |
tellerbe - Posts: 109 |
How do I make candles shorter or longer? I know it is simple I just can't remember how to do it. T. Ellerbee |
[2016-04-27 04:21:04] |
You can use the Interactive Scale Range feature for this: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleRange Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
