Date/Time: Sat, 28 Dec 2024 08:03:27 +0000
User Email
View Count: 736
[2016-04-25 21:10:19] |
Sierra Chart - Max - Posts: 5770 |
Please take a look at the screenshot. The prospect would like to see the lines of the histogram being thicker and the shadow of the candles more visible. Is there a way? Thank you Sierra Chart Support Date Time Of Last Edit: 2016-04-25 21:10:48
Cattura.PNG / V - Attached On 2016-04-25 21:10:05 UTC - Size: 38.81 KB - 271 views |
[2016-04-26 05:10:46] |
To make the Volume bars thicker requires increasing the Width of the Volume Subgraph of the Volume study. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#SubgraphsTab If you are referring to the High to Low portion of the candlesticks, those can be made thicker by adjusting the Width of the following settings in Global Settings >> Graphics Settings: Bar High-Low Down Bar High-Low Up Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-26 05:11:31
