Date/Time: Sat, 28 Dec 2024 22:43:49 +0000
J81 changes order type instead of only offset
View Count: 849
[2016-04-25 16:14:36]
phaedonk - Posts: 352
I am using cell J81 in spreadsheets for trading. I want it to only change the value of the stop order I have in the TW. I use a trailing stop order. Instead, it also changes the type to a simple stop order. This is unwanted, it should not change the order type I have already selected. Can you please change this behavior?
[2016-04-25 17:14:33]
We will see about this.
[2016-04-28 09:27:50]
This prohibits me from auto-trading my system. If you have a fix ready please notify me, as I'm waiting for it. Thank you.
[2016-04-28 13:26:57]
Sawtooth - Posts: 4143
You can move TW Attached Order stops and targets with spreadsheet formulas using the Trade Management By Study study.
http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#StudyControlledTargetsStops
[2016-04-28 17:22:38]
This is not regarded as a bug. This is by design.
We are thinking about how to let the automated trading study on the spreadsheet control the order type. But we cannot get to this soon.
[2016-05-04 18:57:08]
Thanks a lot Tom, this works like a charm! I only need to keep in mind that I should not switch the chart to a high timeframe, as this will make the trailing stop update lag. I have gone for the End of bar update, as the "every n seconds" hits me with excessive Eurex modification fees.
