Date/Time: Sun, 27 Sep 2026 01:29:21 +0000
sync of locked fill space
View Count: 1917
| [2016-04-25 12:57:00] |
| cross - Posts: 70 |
Damn, this really annoys me! I don't know from which version this is the case but as far as I remember this was not always as it is now. See the attached chartbook. There are two charts with the scroll position linked, and with different zoom levels. On both charts locked fill space is set. If you increase the locked fill space eg. by Ctrl+mouse wheel on the small chart (left) then the fill space on the linked chart will also grow. This is really bad! The big chart will also enlarge the fill space with just the same amount of bars.. so because of the higher zoom level this moves a large part of that chart off the window. Or vice versa, shrinking the fill space on the big chart alters the small chart too. I wanna grow/shrink the fill space on the specific chart only and don't bother the other linked ones. Scroll position should not alter the fill space. If I modify the locked fill space on a chart I need to switch fill space locking off, re-adjust the fill space and then lock again.. on all other linked charts, one by one. Please, look into this! Thank you in advance! |
Attachment Deleted. |
| [2016-04-25 23:17:07] |
We need some time to look this over and determine a proper solution.
| [2016-04-26 18:40:15] |
This will be solved in the next release.
