Date/Time: Sat, 28 Dec 2024 09:09:13 +0000
OEC Data/SC Realtime Data
View Count: 752
[2016-04-25 06:43:33] |
User78442 - Posts: 260 |
I just switched brokers/data to S5/OEC - I'm not getting the (M) symbol on my charts - Is the SC Data backfilling the OEC Realtime data? I'm sending a Message Log |
[2016-04-25 06:51:10] |
This is the problem: NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2016-04-25 06:54:38 You must be connected to a live account and not a simulated account like you are. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-25 17:26:53] |
OK, live account should be active later today
