Date/Time: Sat, 28 Dec 2024 22:49:31 +0000
Time Alert thinks the time has passed
View Count: 755
[2016-04-24 18:22:57]
User13668 - Posts: 294
Why can I not set a Time Alert to occur in 5 minutes time to test the functionality.
As you can see from the attached the error message is saying the time is in the past, but as you can see the Global Time setting at the very top of the screen is showing 14:16 and the alert is set for 14:20.
I can confirm the particular chart is set to look to the Global Time Zone which itself is set to New York.
I am posting this message right now at approx 14:22 NY time.
imageTimeAlert.PNG / V - Attached On 2016-04-24 18:22:43 UTC - Size: 38.52 KB - 273 views
[2016-04-24 21:27:24]
This will be solved in the next release.
The time being compared to was not being adjusted to the Sierra Chart Time Zone but rather the local time zone on the computer.
[2016-05-07 12:44:25]
I downloaded v1400 some days AFTER this post of yours, but the problem still exists.
Which version was it fixed in?
[2016-05-07 18:15:13]
Not exactly sure of the version but install the current version 1406.
