Date/Time: Sat, 04 Jul 2026 03:28:52 +0000
Alert sounds 1 to 150
View Count: 1778
[2016-04-22 17:57:50]
User830652 - Posts: 21
Where do I find the above?
I went to " C:\SierraChart\SierraChartTransActMA\AlertSounds " and did not find the above.
I have my "Global Settings" "Alert / General 3" lock on "Alert 1" and there is no none setting.
Thank you
[2016-04-22 18:21:46]
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#AlertSoundSettings
[2016-04-22 18:50:46]
Been there. I am still locked into one sound for all of my alert conditions.
Why?
[2016-04-22 19:00:14]
The documentation linked to explains how to set a different alert sound file (if available) for each Alert Number.
Date Time Of Last Edit: 2016-04-22 19:00:30
[2016-04-22 19:41:10]
Maybe I am just too dumb to figure it out.
[2016-04-22 20:41:37]
It is not completely clear what you want to do.
[2016-04-22 21:03:10]
Correct. I have locked a sound file into global settings that will not allow me to modify other sounds.
[2016-04-22 21:29:35]
Sawtooth - Posts: 4335
You assign .wav files to Alert numbers in Global Settings >> General Settings >> Alerts/General3 tab.
You assign alerts to Alert numbers in each study's Alerts tab (in most cases).
[2016-04-25 00:59:42]
This does not make sense.
Here are the step-by-step instructions to change the particular alert sound for a particular Alert Number (#):
We have clarified them.
[2016-04-25 03:44:36]
This image should also make it more clear how this works:
https://www.sierrachart.com/images/AlertNumberSettings.png
[2016-04-25 14:27:07]
I found the error. Windows error code: 0. Had to re-save the .wma files and convert them to .wav . Just changing the file extensions from .wma to .wav did not work.
All fixed now.
Thank you
[2016-04-25 16:29:08]
OK good.
