Date/Time: Sun, 02 Aug 2026 07:03:57 +0000
Too many unnecessary clicks
View Count: 1056
| [2016-04-22 13:01:59] |
| User472677 - Posts: 391 |
Hello, I am making good progress. Your implementation of many features is excellent. In sierra I can set alert on a ray and set settings for that alert. During a typical day I am drawing about 200 rays with alarms.it seems in sierra it takes many clicks. everyday it means thousands of clicks. In my present software this is a ONE CLICK OPERATION. here is how it works. 1. there is a global setting where I can set all settings of a default alert on a ray. Once set I do not need to reenter these settings. 2. there is a global setting that automatically adds the default alert anytime I draw a ray. 3. rays with alerts are always dotted so I can visually tell without clicking which ray has an alert Please help implement the foregoing, this is very important. As a very active trader, my focus is on the trades and click as little as possible for alerts. Thank you for your help. |
| [2016-04-22 18:29:35] |
We realized that apparently we did not answer this previously when it was posted in the original thread. What you want to do is supported. Here is the relevant documentation: Chart Drawing Tools: Drawing Tool Configuration Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition 3. This is not supported but the color of the line can be set to change when the Alert Condition is true. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-22 18:30:06
