Date/Time: Sat, 28 Dec 2024 07:39:19 +0000
STOCK EXCHANGE DATA
View Count: 670
[2016-04-22 10:35:24] |
User82615 - Posts: 106 |
HELLO I WOULD LIKE TO WORK WITH SIERRA CHARTS BUT WITH EUROPEAN STOCK EXCHANGES DATA ; IS THIS POSSIBLE? THANK YOU VERY MUCH |
[2016-04-22 10:41:07] |
Yes through the Teletrader Data service: https://www.sierrachart.com/index.php?page=doc/TeleTrader.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
