Date/Time: Sun, 04 Oct 2026 18:28:37 +0000
customized chart shortcut
View Count: 971
| [2016-04-22 05:11:27] |
| User65950 - Posts: 3 |
I added the BLANK tool to my customized chart shortcut menu. When activated it removes candle sticks and OHLC bars without removing indicators eg, moving averages ,keltner channels etc. which is fine. But I cannot find an undo for it, which will enable me to turn it on and off, thereby enabling me to toggle between blank and undo blank Thanks |
| [2016-04-22 05:29:30] |
You also need to add "Candlestick Bars" or "OHLC Bars" to the Chart Shortcut menu and select one of those.
