Date/Time: Sat, 19 Sep 2026 10:13:12 +0000
Can I duplicate a study?
View Count: 1182
| [2016-04-21 23:01:31] |
| User244592 - Posts: 49 |
I am using volume by price with certain settings and I have those set as default. I want to also use it with several different settings and would rather not have to load the default and go through resetting the values since I move it around the chart. Is there any way to have 2 different studies each with its own default. I read the source code area in help but dont have a clue what it means. Thank you for your help
| [2016-04-22 06:18:55] |
Refer to the Analysis >> Studies >> Duplicate button: Chart Studies: Duplicate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
