Date/Time: Wed, 23 Sep 2026 18:02:10 +0000
new live package
View Count: 1230
[2016-04-21 18:43:52]
User865310 - Posts: 2
account name seanpeter using cqg data thru (dorman) data will not connect..is yellow message
...waitng to connect but never does. please help
[2016-04-21 18:58:06]
Software version: 1395 | 2016-04-21 11:37:02
Uses New Spreadsheets | 2016-04-21 11:37:02
Usage end date: 2016-07-23 | 2016-04-21 11:37:02
Enabled for: Advanced Features. | 2016-04-21 11:37:02
Enabled for: Sierra Chart Historical Data Service. | 2016-04-21 11:37:02
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-04-21 11:37:02
Current selected Data/Trading service: CQG FIX Trading | 2016-04-21 11:37:02
Chart Update Interval: 500 | 2016-04-21 11:37:02
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-04-21 11:37:02
2016-04-21 11:37:06 Local computer time | 2016-04-21 11:37:02
2016-04-21 18:37:06 Local computer time in UTC | 2016-04-21 11:37:02
2016-04-21 11:37:06 Local computer time in SC Time Zone | 2016-04-21 11:37:02
2016-04-21 18:37:06 Server time in UTC | 2016-04-21 11:37:02
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-04-21 11:37:02
Program path: C:\SierraChart\ | 2016-04-21 11:37:02
Data Files path: C:\SierraChart\Data\ | 2016-04-21 11:37:02
OS Version Number: 6.2 | 2016-04-21 11:37:02
Locale Setting: C | 2016-04-21 11:37:02
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-21 11:51:20
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-04-21 11:51:20
socket (131) | Connected. | 2016-04-21 11:51:20
CQG FIX: Sending the Logon message. | 2016-04-21 11:51:20
CQG FIX: Received a Logout message. Text = Trader is not enabled to use SierraChart. Please contact your FCM. | 2016-04-21 11:51:21
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-21 11:51:21
socket (131) | Shutdown and closed. | 2016-04-21 11:51:21
CQG FIX: Disconnected. | 2016-04-21 11:51:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-21 11:51:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-21 11:51:21
CQG FIX Trading | Disconnected. | 2016-04-21 11:51:21
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-21 11:51:21
The above has been sent to support. | 2016-04-21 11:52:57 *
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-04-21 11:52:57
HTTP connection to www.sierrachart.com:80 (132) | Connected. | 2016-04-21 11:52:57
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2016-04-21 11:52:58
HTTP connection to www.sierrachart.com:80 (132) | Closed. No error. | 2016-04-21 11:53:03
HTTP connection to www.sierrachart.com:80 (132) | Shutdown and closed. | 2016-04-21 11:53:03
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-21 11:53:21
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-04-21 11:53:21
socket (134) | Connected. | 2016-04-21 11:53:21
CQG FIX: Sending the Logon message. | 2016-04-21 11:53:21
CQG FIX: Received a Logout message. Text = Trader is not enabled to use SierraChart. Please contact your FCM. | 2016-04-21 11:53:21
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-21 11:53:21
socket (134) | Shutdown and closed. | 2016-04-21 11:53:21
CQG FIX: Disconnected. | 2016-04-21 11:53:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-21 11:53:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-21 11:53:21
CQG FIX Trading | Disconnected. | 2016-04-21 11:53:21
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-21 11:53:21
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-21 11:55:21
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-04-21 11:55:21
socket (136) | Connected. | 2016-04-21 11:55:21
CQG FIX: Sending the Logon message. | 2016-04-21 11:55:21
CQG FIX: Received a Logout message. Text = Trader is not enabled to use SierraChart. Please contact your FCM. | 2016-04-21 11:55:21
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-21 11:55:21
socket (136) | Shutdown and closed. | 2016-04-21 11:55:21
CQG FIX: Disconnected. | 2016-04-21 11:55:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-21 11:55:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-21 11:55:21
CQG FIX Trading | Disconnected. | 2016-04-21 11:55:22
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-21 11:55:22
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-21 11:57:22
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-04-21 11:57:22
socket (138) | Connected. | 2016-04-21 11:57:22
CQG FIX: Sending the Logon message. | 2016-04-21 11:57:22
CQG FIX: Received a Logout message. Text = Trader is not enabled to use SierraChart. Please contact your FCM. | 2016-04-21 11:57:22
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-21 11:57:22
socket (138) | Shutdown and closed. | 2016-04-21 11:57:22
CQG FIX: Disconnected. | 2016-04-21 11:57:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-21 11:57:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-21 11:57:22
CQG FIX Trading | Disconnected. | 2016-04-21 11:57:22
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-21 11:57:22
Date Time Of Last Edit: 2016-04-21 19:13:20
[2016-04-21 19:13:01]
Could you contact your broker and let them know you are getting this message:
You need to tell them, that your CQG account needs to be set to use Sierra Chart. They need to contact CQG for additional help if needed.
