Date/Time: Sat, 28 Dec 2024 07:48:35 +0000
Show Alert on Chart
View Count: 703
[2016-04-21 15:24:39] |
User163356 - Posts: 5 |
Hi, Is there a way to show an alert that is working on the chart, similar to what thinkorswim has (see attached). thanks. |
Capture3.JPG / V - Attached On 2016-04-21 15:24:15 UTC - Size: 101.54 KB - 247 views |
[2016-04-21 17:20:11] |
Yes. Use the Horizontal Line tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#VerticalandHorizontalLines And set an Alert Condition on it: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
