Date/Time: Mon, 05 Oct 2026 07:06:20 +0000
Spreadsheet/Auto Trading entry
View Count: 1290
| [2016-04-21 15:07:50] |
| JamesP - Posts: 89 |
Hello, I'm trying to figure out how to get a better entry within an automated/spreadsheet strategy. For example rather than take a buy market order at bar close(when conditions are met) I'd like to buy two ticks below the bar close. |
| [2016-04-21 16:53:21] |
Specify the order as a Limit order and specify the price: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#BuyEntryLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-21 18:23:14] |
The price will be different for each trade, is there a way to set a limit order at -2 ticks(ES) from the bar close for a long? Or 5 ticks from low of entry bar for a long?
| [2016-04-22 06:47:39] |
You have to write a formula in the limit price cell to calculate this price. So you can do what you require. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#LimitPrices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-22 06:48:08
