Date/Time: Fri, 27 Dec 2024 16:19:34 +0000
sc.GetStudyArrayFromChartUsingID
View Count: 824
[2016-04-20 20:46:17]
User99735 - Posts: 234
Am trying to access data in cols AA of a spreadsheet from a strategy, as follows, using 16 for column AA / Subgraph number is not working. What would be the correct number to use.
SCFloatArray SpreadSheetColAAArray;
  sc.GetStudyArrayFromChartUsingID(ChartNumber, StudyID, 16, SpreadSheetColAAArray);
Regards
Vivek
Date Time Of Last Edit: 2016-04-20 20:46:54
[2016-04-20 21:13:11]
The index is zero based. So 16 is correct.
Sounds like a calculation precedence issue.
Make sure the study sets:
sc.CalculationPrecedence = VERY_LOW_PREC_LEVEL
And is at the end of the list of studies to be calculated.
For more information, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyCalculationPrecedence
