Date/Time: Wed, 23 Sep 2026 19:55:00 +0000
multiple contracts with stop to Break-even after target 1
View Count: 1809
[2016-04-20 16:58:40]
User66360 - Posts: 81
Id like to run 2 contracts on ES, with an initial target of 4 points, after the 1 target is hit, one contract is closed, I would like the second contract stop to go automatically to break even. How can I do this? Thanks
[2016-04-20 17:40:04]
Refer to this page:
Attached Orders
You will need to use the Move to Breakeven for Stop settings.
There are some included examples.
[2016-04-21 00:24:09]
I read through that and am still not finding it. Can you please be more specific? Specific instructions please?
[2016-04-21 06:17:57]
Do you already have the Stop and Target order set up on the Targets tab of the Trade Window?
If so, then refer to the instructions here:
Attached Orders: Move to Breakeven for Stop
[2016-04-22 12:03:57]
I'm missing something. Its hitting the target 1 and the stop is not moving to break even for the remaining contracts. I've read through other posts looking for this and have not found anything. I have seen y'all build a custom order entry to download for someone else. Can you please build me one and Ill just download it and save it to my data folder? thank you
[2016-04-23 05:33:44]
Yes we can do that. No problem but Sierra Chart already has a 2TargetsWithBEStop.twconfig Trade Window configuration which you can select and shows you how this is done.
Here are instructions to use it:
http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html&CAID=#TradeWindowConfigurations
Let us know if you do not see it or it is not exactly what you want.
