Date/Time: Fri, 27 Dec 2024 16:00:59 +0000
Interactive Brokers CFD symbols
View Count: 986
[2016-04-20 12:26:26] |
User50236 - Posts: 7 |
Hello, please add CFD symbols TLT and GLD for Interactive Brokers. Thank you Martin |
[2016-04-20 17:29:18] |
Sierra Chart does not need to add these. You can manually enter the symbol as needed when opening a chart. Refer to this page: Interactive Brokers Symbols And refer to the format here: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#CFDFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
