Date/Time: Fri, 27 Dec 2024 15:45:38 +0000
Daily reset of indicators
View Count: 846
[2016-04-19 23:53:51]
ForexDirtnap - Posts: 7
I have a question to what I think somewhat easy answer. How do I reset an indicator so that it restarts at the beginning of the day? Per the attached, there is a large gap between the end of the day and the start of the new day.
I do have the session start times the way that I want and this does not seem to have any effect.
imageZNM16 [CBV] [M] Renko 1t #11 2016-04-19 23_50_31.849.png / V - Attached On 2016-04-19 23:51:43 UTC - Size: 67.57 KB - 280 views
[2016-04-20 04:17:41]
Most studies do not reset at the beginning of the day.
If this is what you require, you just need to load 1 day into the chart through Chart >> Chart Settings.
