Date/Time: Sun, 27 Sep 2026 07:13:04 +0000
Calling Persistent Pointers From a different study function
View Count: 1349
| [2016-04-19 22:42:51] |
| enemyspy - Posts: 307 |
Hi. While trying to figure out if this is possible, I was reading through a support request and stumbled accross this. Sierra Chart Engineering Wrote: The persistent variables are held in a STL map which is part of a Study Graph object which is instantiated when a study is added to the chart or a Chartbook is opened which contains a study. Each study is a separate Study Graph object.
Is it possible to Reference this Study Graph object and Call the Persisent pointers from another study? |
| [2016-04-19 23:49:23] |
Never Mind I think I have found it. I think sc.GetPersistentPointerFromChart() is what I was looking for. Fingers crossed that it is what is needed.
| [2016-04-20 02:17:10] |
Yes that is it.
