Date/Time: Fri, 27 Dec 2024 15:44:05 +0000
No Overnight Data
View Count: 668
[2016-04-19 20:09:47] |
TraderVinnie - Posts: 2 |
Hello, I have with AMP Futures Sierra Chart package 5 with CQG for data. I turned my computer on and off everyday. So, when i come in the morning since last week i am unable to get overnight data for the Nasdaq and SP500 but i do get overnight data for the Crude and Gold. Any help as to why ? Thanks in advance, |
[2016-04-19 20:18:43] |
You are running an older version of Sierra Chart. Update to the latest prerelease following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate After this, re-download the data in each Intraday chart with Edit >> Delete All Data and Download. This only needs to be done once per symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
