Date/Time: Fri, 27 Dec 2024 16:35:37 +0000
log message
View Count: 623
[2016-04-19 18:46:19] |
User222821 - Posts: 21 |
hi by this log i can not add or change the target and stop volumes or to make any change on trade window see enclosure
Snímek obrazovky 2016-04-19 v 20.43.55 (2).png / V - Attached On 2016-04-19 18:45:49 UTC - Size: 161.56 KB - 218 views |
[2016-04-19 20:14:03] |
using mac and wine hope it help
[2016-04-19 20:20:17] |
If you are running version 1396 update to 1397. Otherwise, we do not know what the cause is and almost certainly it is related to WINE. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
