Date/Time: Fri, 27 Dec 2024 16:37:11 +0000
Graphic settings for Bid & Ask Lines
View Count: 1091
[2016-04-19 14:53:17] |
superdoug3 - Posts: 40 |
I have enabled Chart > Show Bid & Ask Lines I searched Chart > Graphic Settings for a way to make these lines wider, but can not find the right setting name |
[2016-04-19 17:02:47] |
Refer to: http://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#ShowBidandAskLines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
