Date/Time: Sat, 28 Dec 2024 09:28:04 +0000
Request
View Count: 801
[2016-04-19 13:28:45] |
User623839 - Posts: 108 |
Would you add "Mute All Alerts" to the quoteboard menu maybe even under the alerts tab?
[2016-04-19 16:56:51] |
We will see about this.
[2016-04-20 15:51:11] |
thx
[2016-04-25 12:35:12] |
Al SC Developer - Posts: 434 |
This function is available as a toolbar button under Global Settings >> Mute All Alert Sounds. In the next version, this has also been added to the Quote Board and Alert Manager Window menus. |
