Date/Time: Fri, 27 Dec 2024 16:12:14 +0000
Color code based on percentage % of POC Volume Profile
View Count: 687
[2016-04-19 02:31:16] |
toews&kane - Posts: 209 |
Hi, I think I am looking at a performance issue in Sierra Chart with this enabled in the DOM for volume profile. Although CPU usage and Memory of the system is ok, it seems like when I have this enabled as time progresses and bars get filled I have a little bit of trouble scrolling through other charts. I hope it's not my system issue, I haven't had this performance issue in Sierra Chart before. Only shortly after enabling the color volume profile based on percentage of POC. Anything I should be worried about? I just updated to the latest version of Sierra chart see how it goes. Cheers |
[2016-04-19 03:49:40] |
It would seem unlikely it is related to this. Refer to help topic 30: https://www.sierrachart.com/index.php?l=helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
