Date/Time: Fri, 27 Dec 2024 15:45:44 +0000
[Programming Help] - Use of Global variable in other Study
View Count: 1220
[2016-04-18 19:16:42]
User53601 - Posts: 105
I declared global variable in StudyA:
SCDLLName("StudyA")
int GlobalLastSeparatorIndex;
Then I want to get the value of this global variable in StudyB:
int Test = GlobalLastSeparatorIndex;
Build Output gives this message:
error: GlobalLastSeparatorIndex was not declared in this scope
How to make StudyB aware of the Global variable?
thank you
[2016-04-19 01:49:19]
It really is best to use persistent variables for this:
https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetPersistentInt
And then use this function to get the persistent variable from another study:
https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetStudyPersistentIntFromChart
[2016-04-20 21:15:49]
I used your recommendation and it helped me to move forward with my task. thank you.
However, I still have a question, I think it somehow relates to the first question.
I need to do some processing during recalculation (and then I want to display the result on bars being recalculated):
StudyB is processing an input ( sc.Index value) from persistent variable in StudyA .
The issue is, that the value transferred to Study B is always the same on the recalculated bars,
but it should be different value for each bar ( the sc.Index ).
Seems that all the recalculated bars get as an input the same value, the sc.Index of the last recalculated bar.
STUDY A
int& TestIndex = sc.GetPersistentInt(5);
sc.SetPersistentInt(5, sc.Index);
STUDY B
if ( sc.IsFullRecalculation )
{ int AAA = sc.GetStudyPersistentIntFromChart(sc.ChartNumber,1,5); }
