Date/Time: Sat, 28 Dec 2024 07:20:15 +0000
Crosshair
View Count: 763
[2016-04-18 17:35:24] |
User39772 - Posts: 311 |
When I use the crosshei tool automatically a variable window opesn on the upper right corner of the SC screen. What do I have to do to disable tha variable. I only need the crosshair. If this is not possible how can I at least move tis variables to a location of my choice (it overlaps with the SC menue items). |
[2016-04-18 17:45:42] |
Maybe you are referring to the Compact Tool Values Window or Tool Values window. That can be disabled. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-21 12:50:02] |
Thanks. Is it possible to have a value just for the horizontal line of the crosshai displayed on the right hand side within the scale range. Similar to the value highlighted for the current price, so that i can easily see the price level of the hrizontal line ?
[2016-04-21 17:29:57] |
Yes. There are options to control this. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
