Date/Time: Fri, 27 Dec 2024 15:47:49 +0000
How to write in the chart
View Count: 689
[2016-04-18 14:07:19] |
User625993 - Posts: 7 |
Hello, is it possible to write in the chart? I mean write words, not simpli tracin lines. Thank you Kind regards Patrizia |
[2016-04-18 17:12:38] |
Yes. Use the Type Text tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#TypeText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-18 17:12:54
