Date/Time: Fri, 27 Dec 2024 16:38:30 +0000
Data feed disconnected. Will reconnect.
View Count: 954
[2016-04-18 14:00:21]
User60839 - Posts: 7
I have subscribed for Sierra data feed but I can not connect. I have "SC Data - All Services" in Data/Trade Service Setting. What is wrong?
Regards
Miroslav
Socket (393) | Connected. | 2016-04-18 08:57:15
SC Data - All Services | Connected to server. | 2016-04-18 08:57:15
SC Data - All Services | Sending Encoding Request to server | 2016-04-18 08:57:15
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-04-18 08:57:15
SC Data - All Services | Sending logon request message. | 2016-04-18 08:57:15
SC Data - All Services | Received logon response. | 2016-04-18 08:57:15
SC Data - All Services | Server Name: SC Real-Time Server. | 2016-04-18 08:57:15
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-04-18 08:57:15
SC Data - All Services | Logon error received from server: Not authorized. | 2016-04-18 08:57:15
Socket (393) | Shutdown and closed. | 2016-04-18 08:57:15
SC Data - All Services | Disconnected from the server. | 2016-04-18 08:57:15
SC Data - All Services | Data feed disconnected. Will reconnect. | 2016-04-18 08:57:15
SC Data - All Services | Using username 0 | 2016-04-18 08:57:17
SC Data - All Services | Connecting to the server scdf1.sierracharts.com. Port 443 | 2016-04-18 08:57:17
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-04-18 08:57:17
Socket (394) | Connected. | 2016-04-18 08:57:17
SC Data - All Services | Connected to server. | 2016-04-18 08:57:17
SC Data - All Services | Sending Encoding Request to server | 2016-04-18 08:57:17
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-04-18 08:57:17
SC Data - All Services | Sending logon request message. | 2016-04-18 08:57:17
SC Data - All Services | Received logon response. | 2016-04-18 08:57:17
SC Data - All Services | Server Name: SC Real-Time Server. | 2016-04-18 08:57:17
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-04-18 08:57:17
SC Data - All Services | Logon error received from server: Not authorized. | 2016-04-18 08:57:17
Socket (394) | Shutdown and closed. | 2016-04-18 08:57:17
SC Data - All Services | Disconnected from the server. | 2016-04-18 08:57:17
SC Data - All Services | Data feed disconnected. Will reconnect. | 2016-04-18 08:57:17
SC Data - All Services | Using username 0 | 2016-04-18 08:57:19
SC Data - All Services | Connecting to the server scdf2.sierracharts.com. Port 10048 | 2016-04-18 08:57:19
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-04-18 08:57:19
Socket (395) | Connected. | 2016-04-18 08:57:20
SC Data - All Services | Connected to server. | 2016-04-18 08:57:20
SC Data - All Services | Sending Encoding Request to server | 2016-04-18 08:57:20
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-04-18 08:57:20
SC Data - All Services | Sending logon request message. | 2016-04-18 08:57:20
SC Data - All Services | Received logon response. | 2016-04-18 08:57:20
SC Data - All Services | Server Name: SC Real-Time Server. | 2016-04-18 08:57:20
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-04-18 08:57:20
SC Data - All Services | Logon error received from server: Not authorized. | 2016-04-18 08:57:20
Socket (395) | Shutdown and closed. | 2016-04-18 08:57:20
SC Data - All Services | Disconnected from the server. | 2016-04-18 08:57:20
SC Data - All Services | Data feed disconnected. Will reconnect. | 2016-04-18 08:57:20
[2016-04-18 16:05:36]
Sierra Chart - Max - Posts: 5770
You have not yet fully enabled the Market Data Feed, please continue with step #6 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
Sierra Chart Support
[2016-04-18 16:27:44]
You need to sign the agreement and activate exchanges.
Restart Sierra Chart after any changes to the Sierra Chart Exchange Data Feed on your account.
[2016-04-19 08:44:04]
Thank you for answer, I signed the agreement and restarted Sierra Chart and now I can connect to data feed. I subscribed to NASDAQ Indices but I am not able to see real-time data. Could you please specify the name of instrument in "SC data - all services - data"? Or what is wrong?
I need to see real-time data for NQ, ES, YM. Could you please specify name of these instruments a correct setting?
Regards
Miroslav
[2016-04-19 09:31:04]
You activated the wrong exchange.
Do you have a futures trading account?
[2016-04-19 13:47:40]
Yes,
I have AMP TRADING account with CQG. But I would like to use Sierra Chart data with AMP account. What do you recommend?
[2016-04-19 16:59:37]
You need to activate the CME Group Exchange for 3.25 USD/month here:
https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures
Follow the instructions here to set Sierra Chart to connect to your trading account:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices
