Date/Time: Fri, 27 Dec 2024 15:42:43 +0000
Linear Regressive Slope
View Count: 768
[2016-04-18 13:47:04] |
jivetrader - Posts: 410 |
could you please provide the math behind this study ? the manual has no information.
[2016-04-18 17:16:13] |
It is not something we would document. You have to look at the source code. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
