Date/Time: Fri, 27 Dec 2024 16:27:23 +0000
David G.
View Count: 693
[2016-04-17 21:50:09]
User519800 - Posts: 13
Just Upgraded the latest from your software and Now my Login Shortcut doesn't Work anymore..Help Please..tks.
[2016-04-17 22:14:45]
We are not fully understanding this.
Go to the folder that Sierra Chart is installed to:
C:\SierraChart\
Run the SierraChart.exe program.
Make sure to follow through the setup instructions for the particular trading platform service you are using:
https://www.sierrachart.com/index.php?page=doc/Data.php#Services
We see Sierra Chart is currently set to CTS T4 FIX but in the case if you are using AMP as the broker that would not make sense.
Date Time Of Last Edit: 2016-04-17 22:15:22
