Date/Time: Fri, 27 Dec 2024 16:03:43 +0000
Chart DPL and Trading Window DPL Commissions?
View Count: 1522
[2016-04-17 12:31:51] |
JRA - Posts: 97 |
How can I make the DPL(Daily P&L) on the left upper corner of the chart and on the trading window as well display the p&L after commissions?
[2016-04-17 21:51:43] |
This is not supported. As the documentation explains here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#SymbolSettingsControls The commission setting only applies to the Profit/Loss values in the Trade Activity Log window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
