Date/Time: Sat, 28 Dec 2024 08:26:35 +0000
final take on cpu load
View Count: 2140
[2016-04-25 16:31:28]
Just to make absolutely certain you are on the latest release which will not load User Contributed Studies in safe mode, after the close, update Sierra Chart again with Help >> Download Prerelease.
[2016-04-25 21:19:06]
User20450 - Posts: 330
yes i did that , all studies say custom dll , and not on the screen .
and it went down to 4-6% for 1 chart book which is still not great for high speed trading , but when i add the same chart books for the other markets it adds 3% each one and totals out over 10% , so not sure why
[2016-04-25 21:53:41]
We do not notice any impact with trading even with CPU usage hovering around 10 to 13 % with 8 cores.
[2016-04-25 23:53:30]
well i have heard multiple issues from others of order entry lag and modification of order lag over 10% , thats just way to high imho
i click on the chart dom to place and order and there as a half second lag before it appears , also dragging the chart has lag ,
what else can cause this issue ?
[2016-04-26 00:03:42]
The half second lag is probably due to the Chart Update Interval.
So what you can do is on the particular Chart/Trade DOM you are trading from, reduce the Chart Update Interval for that specific chart:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ChartUpdateInterval
Date Time Of Last Edit: 2016-04-26 00:05:21
[2016-04-26 00:28:25]
so lower it to 500 or lower as all charts were at 1000 to lower cpu which dosent seem to change from 500-`1000
