Date/Time: Thu, 10 Sep 2026 20:13:46 +0000
CQG DATA AMP - NOT WORKING AFTER UPDATE
View Count: 1035
| [2016-04-16 11:06:10] |
| User367949 - Posts: 25 |
Hi Guys, My CQG data with AMP was working fine in the day yesterday with the /ES I read the message about the CQG data feed messing up. I was doing some backtesting last night it kept dropping connection, so went and updated the version you advise x3 times but it's still having trouble connecting to CQG fix amp Same as current SC version can't connect either. Do you know how long it be till this connection is fixed? thanks! |
| [2016-04-16 19:40:37] |
We are not aware of any problem. Being CQG is an external service we do not have any direct control over this. Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-17 21:46:14
| [2016-04-17 20:03:36] |
Working ok now thanks
