Date/Time: Fri, 27 Dec 2024 16:06:25 +0000
Color Bar open price crossover with BB
View Count: 899
[2016-04-16 03:40:54]
User398047 - Posts: 5
Hi there,
I have 2 studies attached. One is Bollienger Bands and another Color bar on conditions.
Can you please advise what is the formula if I want the bar to change color whenever the open price crosses with external BB's and where to put this formula.
[2016-04-17 21:58:48]
Use the Color Bar Based on Alert Condition study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245
The formula is:
=OR( CROSSOVER (ID1.SG1, O) , CROSSOVER (ID1.SG3, O) )
This assumes ID1 is the identifier for the Bollinger Bands.
The formula needs to be entered on the Color Bar Based on Alert Condition study. Here is the documentation:
https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#EnterAlertOnStudy
[2016-04-18 01:00:04]
Thanks,
Can you please advise on what would be the best way to attach the sound alarm based on the same conditions as well?
[2016-04-18 03:17:13]
Please ignore the audio sound. I've found it.
The formula doesn't seems to be working properly though.
Bollinger Bands identifier is ID:2 so I've changed the formula to =OR( CROSSOVER (ID2.SG1, O) , CROSSOVER (ID2.SG3, O) )
I've restarted the program but the candles are not being colored at all.
When applied the original one sent by you earlier with ID1 the candles are colored but not correctly. A lot of them where price is far away from BB's are colored too.
[2016-04-18 03:44:30]
I've changed the formula slightly to =OR( CROSSOVER (ID1.SG1,H) , CROSSOVER (ID1.SG3,L) )
It seems it's more accurate than before however there are still a lot of candles which are not being colored or there are a lot of which are being colored but theoretically shouldn't as they don't cross the BB's.
Any ideas how to tune it in and why there are so many discrepancies.
[2016-04-18 17:25:29]
It is hard for us to tell you what formula to use because we do not know exactly what you want to do.
It is best that you work out the proper formula. Here is the relevant documentation:
[2016-04-19 04:22:17]
Well, All I want to do is to color the candle once crosses with the external Bollienger Band.
The results are not very consistent on Sierra Chart in this respect, from what I was able to observe.
[2016-04-19 04:25:04]
The consistency is strictly due to the formula you are using. The evaluation of a formula is 100 percent perfect and that is not where the problem is.
You still need to define exactly what you want to do.
Your description is still vague and nonspecific. What specifically is meant by this:
A candlestick consists of 4 values.
Date Time Of Last Edit: 2016-04-19 04:25:22
[2016-04-19 04:36:14]
Here is the result from the formula given in post #2:
http://www.sierrachart.com/image.php?Image=1461040541946.png
[2016-04-19 05:24:34]
If the Alert Formulas do not appear to be evaluating correctly, it could have to do with the Value Format which explained here:
https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#ValueFormat
