Date/Time: Sun, 05 May 2024 23:58:37 +0000
[User Discussion] - Ackin's indicators (SCH users requests for studies) - Update list
View Count: 66987
[2020-12-04 21:06:13] |
Ackin - Posts: 1865 |
Users are seeing 0:00 on the timescale at each bar or the columns after the last bar in the chart have an incorrect time or 0:00.
*IMPORTANT* Notice: Custom Study Improperly Altering Time Scale of Chart If you see this error, probably you use an old library. Make an update. This doesn't only apply to my libraries but to all custom libraries and libraries created by any third party that have been compiled to version 2195 and you are using them in higher versions. 2195 Release Date: 2020-11-11
Therefore, any ACSIL study which uses these functions needs to be recompiled for version 2195 or higher. If the study is not recompiled, then the functions will do nothing and add an error message to the Sierra Chart Message Log.: sc.GetStartDateTimeForTradingDate, sc.GetTradingDayStartDateTimeOfBar, sc.ConvertDateTimeToChartTimeZone, sc.DateStringToSCDateTime, sc.AdjustDateTimeToGMT, sc.TimePeriodSpan, sc.TimeStringToSCDateTime, sc.DateStringDDMMYYYYToSCDateTime, sc.CalculateTimeSpanAcrossChartBars, sc.GetEndingDateTimeForBarIndex, sc.GetEndingDateTimeForBarIndexFromChart, sc.ConvertDateTimeFromChartTimeZone, sc.ConvertDateTimeFromChartTimeZone. https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2195 Please make sure you really have a library for version 2199 and higher The control is simple: Menu / Analysis / Studies / Add custom studies / Library name (File name and version for which it was compiled) Date Time Of Last Edit: 2020-12-12 15:22:25
Lib_v2192_in_SC_v2204.png / V - Attached On 2020-12-04 21:07:01 UTC - Size: 36.94 KB - 457 views |
[2020-12-21 14:10:53] |
RIFT - Posts: 124 |
Hello Ackin, I use Fastkeys to change my values in different studies, e.g. the Delta Dots Study V2 (simplesystemtrading). Is there a study where I can pic specific values of studies to have them displayed on my chart? e.g. where I can enter the string of the value in the study and then the actual value gets displayed? It is because if I Change multiple values regulary I can not remember all the values I entered. Thx advance for your help.
[2020-12-21 14:12:44] |
RIFT - Posts: 124 |
Hello Ackin, can you please create a study for me where I can set the value of the color bar alert condition in the study (see the 2 screenshots)? I want to change the value with fastkeys. Thank you very much! |
2020-12-21_15h01_26.png / V - Attached On 2020-12-21 14:12:30 UTC - Size: 20.81 KB - 452 views 2020-12-21_15h01_40.png / V - Attached On 2020-12-21 14:12:35 UTC - Size: 20.84 KB - 458 views |
[2020-12-21 14:15:11] |
Yes I can, I already sent you an email. Over the next week, now I have accumulated work on the Christmas update.
[2020-12-27 00:58:55] |
User48838 - Posts: 112 |
Hello Ackin, I was able to create a smoothed VbP chart for the ES but when I duplicated it for NQ and RTY there seems to be an issue. COuld you take a look please, TY
2020-12-26_19-57-02es.png / V - Attached On 2020-12-27 00:58:37 UTC - Size: 122.74 KB - 450 views 2020-12-26_19-58-08nq.png / V - Attached On 2020-12-27 00:58:44 UTC - Size: 72.77 KB - 455 views |
[2020-12-27 13:58:47] |
Trader&Hunter - Posts: 129 |
https://sst.frl/smooth
[2020-12-27 14:13:55] |
I will add diagonal imbalance to it and other improvements according to the requirements of what are sent to me by email so I will look at this as well. It looks like a "no-running chart with no data connection". Is it the same for replay? Date Time Of Last Edit: 2020-12-27 15:33:25
[2020-12-27 16:30:08] |
The chart was loaded while the market was closed, but even in replay the smoothed VBP is showing the issue on NQ but not ES. TY
[2020-12-27 16:38:51] |
Strange ... thank you for the warning. I'll fix it if I find out the cause. Please post similar suggestions and comments directly to my forum in the thread describing this study to maintain clarity and history of development. Thank you Date Time Of Last Edit: 2021-02-06 17:28:01
[2021-01-12 14:25:28] |
007700 - Posts: 43 |
Hello Ackin,Many thanks for your help to fix our indicator after many attempts and no success thank god we found you as you where able to resolve it very quickly You Are A Lifesaver Many Thanks |
[2021-01-21 09:09:24] |
If you want to use my free libraries you must have Sierrachart updated to version 2220 and higher. This applies to: Free2019 (260 studies) Free2020 (140 studies) Free2021 (will released January 31, 2021) Sierrachart Version 2215-2219 does invisible Free2020 library due to modification of DLL Loading Management function. More about this is here: Advanced Custom Studies DLL Loading Management Note. You often write an email that you can't have a higher version of Sierrachart for some reason and whether it is possible to release Free Libraries for lower versions. The problem is that new structures and commands are sometimes used in newer versions of Sierrachart, which are not supported by lower versions. So I can't help you with that. There is a folder with older Free files updates available on the forum where you can download the file for the older version of Sierrachart (...but not all the latest studies will be there. Always only those that were current at the time in the update) Date Time Of Last Edit: 2021-02-18 14:10:04
[2021-02-15 21:10:20] |
User202883 - Posts: 24 |
Ackin, are you still accepting registrations on your forum? I've been waiting for confirmation to gain access to the indicators. Thanks.
[2021-02-15 22:47:11] |
The forum is working, registrations are manual but all resolved.If you have a question or have a problem with registration write me an email: zyp.sierra@gmail.com Date Time Of Last Edit: 2021-04-10 12:57:35
[2021-02-17 00:15:47] |
User71961 - Posts: 144 |
Ackin - does your library have the NOPE study? (Net Option Pricing Effect) (see attached image for the formula calc) If not, can it be added? Here is what the result looks like for SPY https://nopechart.com/?ticker=SPY&date=2021-02-16 tho i would think that applying this to ES futures would yield a better result vs SPY (SPY still looks good tho) Date Time Of Last Edit: 2021-02-17 00:22:08
[2021-02-18 14:05:50] |
NoIf not, can it be added?
I'm sorry, but definitely not next month or this month. I have many unresolved requests from earlier times on the CZSK forum.Look: https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php |
[2021-02-28 05:22:39] |
User509345 - Posts: 44 |
I can't open the website.
[2021-02-28 09:23:08] |
Apologized for that. Probably some temporary outages on the part of the hosting provider.
[2021-03-12 23:59:35] |
Update/upgrade list 01/02/03 2021 Custom Studies Store: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Updated studies: Edit Numbers Bars: Pullback Range Edit Text Display For Study from chart Edit Bar_Size Marker Edit Swing high low pivot line Edit Bar Numbering - SuperTrend Stop Edit SuperTrend Stop - improved Edit Numbers Bars: Highlights Edit Tab values Edit Swing high low pivot line Edit Numbers Bars: Highlights New studies: - Volume At Price (Max Total Volume - Automatic) Modify v1 - Bar_Size Marker - Bar_Min Volume Marker - Numbers Bars: Pullback Range - ZigZag - improved (SG Reference) - ATR levels - Alert Extension Lines - EWAP3 - EWAP4 - Bar_Size Marker - Bar_Min Volume Marker - Numbers Bars: Pullback Range - ZigZag - improved (SG Reference) - Bar Numbering - Gann HiLo Activator - SuperTrend Stop - improved2 - Standard Deviation Bands - Adaptive - Standard Deviation Bands - DEMA - Standard Deviation Bands - Hull - Standard Deviation Bands - T3 - Standard Deviation Bands - TEMA - Standard Deviation Bands - Triangular - Daily High/Low Zones with alert - VbP ID: Color Developing POC Based on Volume - ATR levels - Alert Extension Lines - Custom Horizontal Grid - Volume Weighted Average Price VWAP (start time) - Daily High/Low Zones with alert - VbP ID: Color Developing POC Based on Volume - Daily High Low Band - Zig Zag Oscillator - Trading: Trade Open Profit/Loss - Trading: Trade Cumulative Profit/Loss - Trading: Trade Average Price - Trading: Trade Daily Total Quantity Filled - Trading: Trade Price During Position - Trading: Trade Maximum Open Position Profit - Trading: Trade Maximum Open Position Loss - Trading: Trade Time Duration - TPO ID: Info - TPO ID: Peak/Valley Lines - VbP ID: Info - Bar Values (Specific time) - Bar Values (xx Bars ago) - Trading: Watchdog (Trades) - Trading: Watchdog (Losing Trades) - Custom Horizontal Grid - VWAP with start time - Bar Numbering - Last High - Bar Numbering - Last Low - Bar Numbering - Since Last Trade Entry - Bar Numbering - Since Last Trade Exit - Bar Numbering - Volume Decreasing - Bar Numbering - Volume Increasing Date Time Of Last Edit: 2021-03-28 18:04:19
[2021-04-02 19:12:35] |
User664240 - Posts: 206 |
I've registered with my correct SC user name a few times and have yet to receive a password by e-mail. Is there a protocol I'm missing?
[2021-04-02 19:38:51] |
Write me please a direct message with an SC account or email (zyp.sierra@gmail.com) |
[2021-04-03 23:22:05] |
Ticks - Posts: 174 |
Ackin, Can you make a rising trailing drawdown (max loss)study that can display in a subgraph or text form on the chart? The study would allow a trader to set the starting account balance at the beginning of their training but would not have to set it again the next day. It would maintain the starting account balance, trailing drawdown,profit target, max account stoplost/drawdown, etc for the chart its placed on even after SC has been shut down and restarted at a later date It would be based on the details from LeeLoo https://support.leelootrading.com/kb/a86/how-does-the-rising-trailing-drawdown-max-loss-work.aspx?KBSearchID=8484 I am looking to practice having a evaluation account and controlling this drawdown before signing up for a real evaluation. Date Time Of Last Edit: 2021-04-03 23:22:53
[2021-04-04 06:23:08] |
Ackin, Can you make a rising trailing drawdown (max loss)study that can display in a subgraph or text form on the chart? The study would allow a trader to set the starting account balance at the beginning of their training but would not have to set it again the next day. It would maintain the starting account balance, trailing drawdown,profit target, max account stoplost/drawdown, etc for the chart its placed on even after SC has been shut down and restarted at a later date It would be based on the details from LeeLoo https://support.leelootrading.com/kb/a86/how-does-the-rising-trailing-drawdown-max-loss-work.aspx?KBSearchID=8484 I am looking to practice having a evaluation account and controlling this drawdown before signing up for a real evaluation. If would be there interest from more people, then I can .... |
[2021-04-04 07:38:13] |
Thanks for the reply. I'm guessing based on this search, a lot of people would be interested in the ability this study would provide. They would be able to use SC with the ability to train for an evaluation without having to spend a lot of money each time to reset evaluations or restart evaluations. https://www.sierrachart.com/SupportBoard.php?do=Search&LimitToForum=0&Query=Rithmic+evaluation&Submit_Search=Search&SortMode=3 |
[2021-04-04 11:05:55] |
NotIll - Posts: 118 |
Hello Ackin, I couldn't find the pace of tape study anywhere. I was waiting for it as you stated a good while ago that it was on your list. Kind regards |
[2021-04-07 12:08:04] |
User573721 - Posts: 26 |
Hi Ackin, do you have any notification service available for a new update? If not could you please consider? I regularly check the folder with new files. It would be more convenient to receive notifications. You have a thousand people on the forum, it would certainly welcome many others :-) Thanks |
[2021-04-07 16:10:06] |
I had a very complicated last month and there weren't many updates. That should improve from this week. To your question: I don't want to send notifications directly to email, but I can display new updates somewhere .... for example Twitter. I'll think about it. Date Time Of Last Edit: 2021-04-10 12:59:36
