Date/Time: Mon, 06 May 2024 10:31:57 +0000
[User Discussion] - Ackin's indicators (SCH users requests for studies) - Update list
View Count: 66998
[2020-11-03 09:46:50] |
User509345 - Posts: 44 |
up bar, top extreme sell imbalance, may be trend reversal , top extreme buy imbalance , trapped traders. up bar, bottom extreme buy imbalance ,may be trend reversal, bottom sell imbalance , trapped traders. POC at extreme will receive alert, that is can be imagine best alert system. |
[2020-11-03 10:43:35] |
If can set extreme threshold, it's very good.
threshold.png / V - Attached On 2020-11-03 10:43:31 UTC - Size: 26.96 KB - 524 views |
[2020-11-03 11:43:16] |
Ackin - Posts: 1865 |
User509345) It's simple, but I'm currently processing some requests in the studies on the SCH volume profile and zyp profile, when it's done I'll look at your request, I think it could be ready for the next update (by Friday +/-) |
[2020-11-03 11:46:33] |
Thanks. I will wait your new post.
[2020-11-03 12:13:25] |
Hi, Ackin. Some orderflow ideas, can you add exhaustion. In a normal market we would expect: lower demand at higher prices – buyers are less willing to buy as prices become more expensive lower supply at lower prices – sellers are less willing to sell as prices become cheaper So we can gauge if prices are too high as we will see less buying volume and if prices are too low we will see less selling volume --from emojitrading, https://www.emojitrading.com/docs/order-flow-basics/key-order-flow-traded-volume-concepts/exhaustion/ |
[2020-11-03 12:30:06] |
It is probably useless to create indicators without any innovation when they are already available from someone else from the same platform. The author of emoji (binaryduke) is also on my forum (among hundreds of other traders) and I don't want to copy his indi. You can buy it from him. Honestly I think that he offers the best from OrderFlow ever for Sierrachart. In a good: Understand that my Free indicators are only to fill the empty space in this area, it means user's requests what Sierrachart refused to create. #125 by next update #129 not, sorry |
[2020-11-03 12:47:44] |
Thanks,I bought twice emojitrading, but I think it is difficult.
[2020-11-03 13:10:30] |
Stay in our community and you'll have more tools for what you do, because I have prepared xy other concepts in connecting numbersbars and DOM (to date more than 150 studies). Their release is limited only by the historical depth of the data (downloadable), which Sierrachart does not yet offer. It is currently too complicated for me to test things in this area. Immediately after that will be the possibility of a tick backtester, which I also have my own, and then it's just a step to automate the orderflow ....
[2020-11-09 11:01:08] |
Hi, Ackin. I didn't see the 2020 ,53) Numbers Bars to Spreadsheet. I want use spreadsheets to mark "exhaused". Wait next update. Thanks. |
[2020-11-13 18:24:48] |
User845062 - Posts: 9 |
Hi Ackin, besides the Numbers Bars to Spreadsheet study I'm interested in another Indicator called "Waddah Attar Explosion". It's a quiet useful trend and volume indicator on mt4/mt5 and I could'nt find it for Sierra Chart. Would it be possible to convert this to Sierra Chart? Thanks. |
[2020-11-13 19:13:09] |
probably yes... |
[2020-11-13 19:21:47] |
The return type for the following ACSIL functions has been changed from a double type to SCDateTimeMS. Previously this was not done when the new integer based SCDateTime/SCDateTimeMS were released since using these types as a return value would lead to an invalid return value when using other compilers other than Visual C++. We have tested again with the compiler used for the Sierra Chart Remote Build functionality and do not observe any problem with this. So we have now changed the return type to SCDateTimeMS. It was necessary to make this change because there is a small degree of floating-point error when using a double type that would lead to a time value being off by a microsecond which can cause a problem when that is not expected. Therefore, any ACSIL study which uses these functions needs to be recompiled for version 2195 or higher. If the study is not recompiled, then the functions will do nothing and add an error message to the Sierra Chart Message Log.: sc.GetStartDateTimeForTradingDate, sc.GetTradingDayStartDateTimeOfBar, sc.ConvertDateTimeToChartTimeZone, sc.DateStringToSCDateTime, sc.AdjustDateTimeToGMT, sc.TimePeriodSpan, sc.TimeStringToSCDateTime, sc.DateStringDDMMYYYYToSCDateTime, sc.CalculateTimeSpanAcrossChartBars, sc.GetEndingDateTimeForBarIndex, sc.GetEndingDateTimeForBarIndexFromChart, sc.ConvertDateTimeFromChartTimeZone, sc.ConvertDateTimeFromChartTimeZone. https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2195 Version 2195 can cause problems with some studies (in previous versions they work fine and in the last not for example: Yesterday last SG value) Please do not upgrade to the latest version, I will try to solve it over the weekend. This applies to the Free2019 and Free2020 libraries so more than 800 users. It will be given priority over new developments. I apologize for the complications associated with it. Date Time Of Last Edit: 2020-11-13 19:23:35
[2020-11-15 11:50:55] |
Hi, Ackin. If have updates, download again or it can automate update. Thanks. |
[2020-11-15 12:01:36] |
User509345 [Direct Messages] - Posts: 36 | Ending Date: 2020-12-15
Hi, Ackin. I didn't see the 2020 ,53) Numbers Bars to Spreadsheet. I added a new study "Numbers Bars: Values to Subgraphs" Free1 2019 Library (SC ver 2192) You will convert everything to a Spreadsheet using Subgraphs. With simple arithmetic operations in Spreadsheets, you can find the "coordinate" you need. I will add the study you are looking for(Numbers Bars to Spreadsheet study) with a direct entry in the Spreadsheet later, but this is more for complete beginners, with the new study mentioned above from today you can also use all operations with numbers from the Numbersbars in the Spreadsheet. If you feel any limitations or you want to add more items, write it pls directly on the forum in the description of the study so that some consistency of questions is maintained. I deal with a lot of emails and requests every day, and despite a good memory, I can forget something. If have updates, download again or it can automate update.
New updates are only possible manually from the forum, I do not support automatic update due to the fact that each user uses a different version of Sierrachart. I don't want to force the latest version of Sierrachart on anyone. The libraries are officially used by over 800 people and unofficially by several hundred others (the original old version without SC account protection). Some have Linux, some Win, some still have a very old version of sierrachart due to libraries from other developers who have not provided an update to the transitional 2151 version. So for these reasons it is nonsense to give an automatic update.
Date Time Of Last Edit: 2020-11-22 22:04:34
[2020-11-16 11:12:33] |
User509345)
Numbers Bars to Spreadsheet Added additional studies to support transfer to Spreadsheets Numbers Bars: SG AVAP Numbers Bars: SG BVAP Numbers Bars: SG Combined AVAP/BVAP Numbers Bars: SG Delta ABVAP Numbers Bars: SG TVAP Numbers Bars: SG VVAP The studies can be downloaded in the update section, I will add other variants during today. Date Time Of Last Edit: 2020-11-17 19:39:13
[2020-11-17 19:38:56] |
Pullback studies: New Numbers Bars: Pullback Difference New Numbers Bars: Pullback H/L New Numbers Bars: Pullback Max Values New Numbers Bars: Pullback Summation New Numbers Bars: Pullback Values to Subgraphs Added additional studies to support transfer to Spreadsheets New Numbers Bars: SG Ratio ABVAP New Numbers Bars: SG Delta TVAP Version 2195 can cause problems with some studies (in previous versions they work fine and in the last not for example:
Yesterday last SG value) Please do not upgrade to the latest version, I will try to solve it over the weekend. This applies to the Free2019 and Free2020 libraries so more than 800 users. It will be given priority over new developments. I apologize for the complications associated with it. v2195 recompilation... With regard to this SCH announcement, I am updating max to the latest back-compatible version and it is 2194 Date Time Of Last Edit: 2020-11-17 19:39:22
[2020-11-20 18:44:06] |
User573721 - Posts: 26 |
Hi Ackin, Could you please create an indicator similar to a moving average, which would have a function of control according to the direction of the bars in the specified period? I would like to see two moving averages. One of the Up bars and the other of the Down bars. Yes, I can use the High / Low turtle channel, but there are also short bars in the Up movement that have higher wicks. It would be good for measuring the inertia of the current market. Thanks :-) |
[2020-11-21 17:35:57] |
Hi Ackin,
Could you please create an indicator similar to a moving average, which would have a function of control according to the direction of the bars in the specified period? I would like to see two moving averages. One of the Up bars and the other of the Down bars. Yes, I can use the High / Low turtle channel, but there are also short bars in the Up movement that have higher wicks. It would be good for measuring the inertia of the current market. Thanks :-) Done. Free1 Update will be tonight Date Time Of Last Edit: 2020-12-12 15:20:10
[2020-11-22 16:32:43] |
Ackin: Thank you very much :-)
[2020-11-24 13:50:48] |
User685606 - Posts: 29 |
Ackin, I tried to register with the link you sent me and sent an email to the gmail email address provided that the bottom, both several days ago with no response.
Date Time Of Last Edit: 2020-11-24 13:51:16
[2020-11-24 13:54:58] |
I answer to all registrations with the correct SC account, I'll send you a DM on this forum. edit: DM sent, set me to "allow contacting you" Date Time Of Last Edit: 2020-11-24 14:05:34
[2020-11-25 03:01:50] |
User48838 - Posts: 112 |
Ackin Could you please take a second (third) look at the request here Ackin's indicators (SCH users requests for studies) - Update list | Post: 234896 TY! |
[2020-11-25 07:40:27] |
Ackin Could you please take a second (third) look at the request here Ackin's indicators (SCH users requests for studies) - Update list | Post: 234896 TY! It was done .... more than a week ago as well as 20 other studies from the last requests here that others are waiting for. It will be all in one of the next updates. I am currently adding email requests to the Free1 library and preparing the library for the upgrade to the 2195+ version. Follow the update folder on the forum and the study will appear there soon. Everything gradually. Date Time Of Last Edit: 2020-11-25 07:57:22
[2020-11-25 19:55:18] |
Request: "The indicator is intended to show in real time that the candle is greater than the VALUE of the ATR indicator. Great if you could adjust the ATR value." attached collection (Sierrachart ver 2192) Download the file / Collection and save it to your Data folder in your Sierrachart How to Use a Study Collection: How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection Date Time Of Last Edit: 2020-11-25 19:55:38
ATR collection.StdyCollct - Attached On 2020-11-25 19:53:01 UTC - Size: 61.57 KB - 374 views |
[2020-11-30 09:47:44] |
Update for Sierrachart v2199+ inserted into upload folder Libraries(Free1): Free 2019 Free 2020 Free Zdislav OFA Member's libraries (Free2) will be added gradually Date Time Of Last Edit: 2021-01-12 14:55:19
[2020-12-04 21:06:13] |
Users are seeing 0:00 on the timescale at each bar or the columns after the last bar in the chart have an incorrect time or 0:00.
*IMPORTANT* Notice: Custom Study Improperly Altering Time Scale of Chart If you see this error, probably you use an old library. Make an update. This doesn't only apply to my libraries but to all custom libraries and libraries created by any third party that have been compiled to version 2195 and you are using them in higher versions. 2195 Release Date: 2020-11-11
Therefore, any ACSIL study which uses these functions needs to be recompiled for version 2195 or higher. If the study is not recompiled, then the functions will do nothing and add an error message to the Sierra Chart Message Log.: sc.GetStartDateTimeForTradingDate, sc.GetTradingDayStartDateTimeOfBar, sc.ConvertDateTimeToChartTimeZone, sc.DateStringToSCDateTime, sc.AdjustDateTimeToGMT, sc.TimePeriodSpan, sc.TimeStringToSCDateTime, sc.DateStringDDMMYYYYToSCDateTime, sc.CalculateTimeSpanAcrossChartBars, sc.GetEndingDateTimeForBarIndex, sc.GetEndingDateTimeForBarIndexFromChart, sc.ConvertDateTimeFromChartTimeZone, sc.ConvertDateTimeFromChartTimeZone. https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2195 Please make sure you really have a library for version 2199 and higher The control is simple: Menu / Analysis / Studies / Add custom studies / Library name (File name and version for which it was compiled) Date Time Of Last Edit: 2020-12-12 15:22:25
Lib_v2192_in_SC_v2204.png / V - Attached On 2020-12-04 21:07:01 UTC - Size: 36.94 KB - 457 views |
