Date/Time: Mon, 06 May 2024 05:48:47 +0000
[User Discussion] - Ackin's indicators (SCH users requests for studies) - Update list
View Count: 66994
[2020-09-29 07:48:19] |
Ackin - Posts: 1865 |
User573721) Done, Library 2020, You can download it New Moving Average - Adaptive with Reset New Moving Average - Block with Reset New Moving Average - Double Exponential with Reset New Moving Average - Elastic Volume Weighted with Reset New Moving Average - Exponential with Reset New Moving Average - Hull with Reset New Moving Average - Simple with Reset New Moving Average - Simple Skip Zeros with Reset New Moving Average - Smoothed with Reset New Moving Average - Triangular with Reset New Moving Average - Triple Exp with Reset New Moving Average - Volume Weighted with Reset New Moving Average - Weighted with Reset New Moving Average - Welles Wilders with Reset New Moving Average - Zero Lag Exponential with Reset New Moving Median with Reset The list has been updated (Post #87) Date Time Of Last Edit: 2020-10-01 11:11:40
[2020-09-29 14:54:46] |
User573721 - Posts: 26 |
Thanks Ackins, good job :-)
[2020-10-01 17:47:30] |
User164131 - Posts: 19 |
Hello Ackin, Thanks for your studies. I have a small question. I'm using «numbers_bars:filtered_POC» study from your package with extended lines, but unfortunatelly when I set line style for this subgraph (SG2) to Alternate — they dissapear. Solid, Dash, Dot linestyles works OK. How can I fix this? Thank you. |
[2020-10-02 09:04:34] |
User164131) I'll look into it, I'll be adding more studies tonight - so there will be a fix for it and added too. Thank you for reporting |
[2020-10-08 13:43:23] |
Hi Ackin, Do you have an indicator that would have a universal input and the output would be various moving averages with a user-defined multiple? Something in the sense of a Ribbon indicator. I would need at least 8 values. I want to use it to test the Market Depth area. Thanks in advance |
[2020-10-08 18:45:43] |
User573721) It is not hard. I'll create it. Maybe I understand the signals you want to see in it. A month ago, I also created a modification of the Ease of Movement study for Market Depth that would probably be more useful. Uni Ribbon will be in the next update, the assumption is this weekend. ... |
[2020-10-08 20:15:27] |
Great, thanks :-)
[2020-10-10 10:16:06] |
User845062 - Posts: 9 |
Hello Ackin, according to your latest List of your Studies in post #87 in Free 2020 there is the Study 50) Numbers Bars to Spreadsheet
I've downloaded your latest 2020 dll-version, but I could not find this study. I would appreciate if you could bring back this study, because I'm really interested to get the numbers bar data to the spreadsheet system for Trading. I would need the bid and ask volumes at each price level from the Numbers Bars study. Thx. |
[2020-10-10 10:49:49] |
Hi, I know. There were several temporary updates when switching to SCH v2156 from v2146 (Reason: There were a few changes in the code but I was pushed by people for a new update because they had new versions of Sierrachart where the old libraries didn't work. Due to several studies, I did not want to delay the process of updating others. So it was temporarily removed). The list will be updated and synchronized over the next week along with new updates. This affected several old studies and about 50 new ones. At the end of next week, there should be over 320 studies in the Free list, including the one you are requesting, and over 500 studies in Members. (Members is also free access for active people on the forum). The following studies will be updated / re-added in the coming days: Free: Numbers Bars to Spreadsheet ZigZag Divergent PinBar 2 PinBar 3 Free2 (Members): Autotrading system TMA channel SR ZigZag VWAP ZigZag Midas Volume profile Reset by Difference Volume profile Reset by Trade ZigZag Tool Volume profile Date Time Of Last Edit: 2020-10-10 10:51:06
[2020-10-10 13:00:02] |
Hello Ackin, In your study called "Numbers Bars: Diagonal differense Imbalance" there is an input "Condition for lines-drawing". And this input has an option "Display only wicks signal". I am coding my simple study (VPOC for bars with extension lines, nothing special) and trying to implement this condition for example — draw line only if VPOC is in lower wick if ((sc.TicksToPriceValue(VolumeAtPrice.PriceInTicks) < sc.Open[sc.Index]) && (sc.TicksToPriceValue(VolumeAtPrice.PriceInTicks) < sc.Close[sc.Index])) { draw_the_line code } but it looks like it doesnt work. How can I define this condition properly? I can post whole code if you need. Date Time Of Last Edit: 2020-10-10 13:00:48
[2020-10-10 13:40:26] |
zyp.sierra@gmail.com btw Your request I'm using «numbers_bars:filtered_POC» study from your package with extended lines, but unfortunatelly when I set line style for this subgraph (SG2) to Alternate — they dissapear. Solid, Dash, Dot linestyles works OK. How can I fix this?
This item is a position from SCH, it does not work even in deafult studies. So this cannot be fixed.
Date Time Of Last Edit: 2020-10-10 14:32:34
[2020-10-11 21:20:45] |
User573721) Hi, It's done. Check update folder. |
[2020-10-21 08:04:23] |
Hi Ackin, I have a proposal for other indicators: Hurst Bands with T3 SRTW system PL-RSI Thanks in advance :-) |
[2020-10-21 10:51:07] |
SRTW system
I'm sorry..No... I know that (I think from the Money Expo conference). Unfortunately, this is not possible. At least until historical market depth data is available for download. The algorithms in this system are based on accumulation from previous periods and are therefore very sensitive to data quality. Then I will definitely create.Hurst Bands with T3
PL-RSI It will be in Friday's update. |
[2020-10-21 17:32:02] |
User573721) additional question: Do you want PL-RSI in percentage scale? Or recalculation in ticks? There is a big difference in the way it is calculated, but also in the visualization. |
[2020-10-21 18:19:48] |
Ackin:) Interesting question. It would be better in percentages. Thanks :-) Date Time Of Last Edit: 2020-10-21 18:20:31
[2020-10-27 23:07:36] |
User48838 - Posts: 112 |
Ackin Could you please take a second look at the request here Ackin's indicators (SCH users requests for studies) - Update list | Post: 234896 TY! |
[2020-10-28 08:01:24] |
User48838) Definitely yes in the near future ... but for the next 14 days I have to work with a new library for automation and back test. After... I'll write here when it's done to give you a try and add suggestions to improve it. Date Time Of Last Edit: 2020-10-28 08:05:50
[2020-10-30 21:03:53] |
Today's update: Volume Point of Control for Bars - improved Extend Bar Value Until Future Intersection Help Slope-Tick Slope-Angle Slope of an MA Hurst Bands T3 Hurst Oscillator T3 Ackin's indicators (SCH users requests for studies) - Update list | Post: 238084 VbP Peak/Valley Lines Volume by Price - Valleys and Peak data not on spreadsheet Tonight I will add Heikin Ashi Smooth T3 + Hull, It's done, I'm just testing if everything is fine .... The next update will be Monday / Tuesday Date Time Of Last Edit: 2020-11-17 19:42:05
[2020-10-31 14:40:14] |
NotIll - Posts: 118 |
Would you please not forget that ''pace of tape'' study?
[2020-10-31 20:21:50] |
Hi Ackin, I can still not find the study 53) Numbers Bars to Spreadsheet
in your updated list form yesterday. I'm still looking forward to have this study back in the 2020 package.
[2020-11-01 11:37:21] |
User509345 - Posts: 44 |
I registration and then ,"Sorry, you are not authorized to view this page. Please, fill out the Registration Form."
[2020-11-01 12:04:06] |
NotIll, User845062) It will be in the next updates (soon). I did not forget that I have a certain system in adding studies because there are different versions from the past that must be corrected due to changes in newer versions of Sierrachart (not only an intervention in rewriting the code but also the possibilities of new functionalities that SCH now offers). User509345) Sending accesses is manual (my intention) not automatically. Check your email - you already have a Login / Pass. |
[2020-11-01 12:07:41] |
Thanks, I can login
[2020-11-03 09:35:41] |
Hi , Ackin . Can you develop a study, add alert at Volume At Price Threshold Alert V2 study at extreme , I set Ask Bid volume diagonal ration, I want receive alert at up bar extreme sell imbalance , may be trend reversal, I want receive alert at up bar extreme buy imbalance , it's may be a trapped traders.Thanks. |
[2020-11-03 09:46:50] |
up bar, top extreme sell imbalance, may be trend reversal , top extreme buy imbalance , trapped traders. up bar, bottom extreme buy imbalance ,may be trend reversal, bottom sell imbalance , trapped traders. POC at extreme will receive alert, that is can be imagine best alert system. |
