Date/Time: Fri, 27 Dec 2024 16:35:25 +0000
Problem with Osaka mini Nikkei DOM
View Count: 888
[2016-04-15 06:03:50] |
User378205 - Posts: 28 |
I am currently using AMP + Sierrachart + CQG AMP recently started supporting OSAKA mini Nikkei (F.US.MJNKM16) My dom looks like that. It seems like DOM isn't displaying in the multiples of 5 Thanks! |
Untitled.jpg / V - Attached On 2016-04-15 06:02:11 UTC - Size: 104.24 KB - 317 views |
[2016-04-15 06:11:39] |
Follow the instructions here to update the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings Once that is done apply them to the chart following these instructions here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps Once that is done, Reset the Trade DOM scale: https://www.sierrachart.com/index.php?page=doc/doc_ScalingTheChartDOM.html#AutoScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-15 06:12:42
