Date/Time: Fri, 27 Dec 2024 15:37:09 +0000
dailynet loss management (loss trigger value)
View Count: 799
[2016-04-14 21:48:55] |
dp7 - Posts: 26 |
Could you clarify the input value of the Daily Net Loss? The tutorial states that it "is entered as a negative number". How should the amount be entered? ie: if setting a daily limit loss of $1000. a-) should it be set at "1000.00ยจ?, or b-) should it be set at "-1000.00"? Thanks, |
[2016-04-15 02:01:23] |
We have confirmed that Daily Net Loss Management >> Loss Trigger Value does need to be a negative number. Use a value of -1000. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
